    Dismiss Notice
Boiler power!
Discussion in 'Plumbing and Central Heating' started by Dannyg78, 10 Feb 2021.
  1. Dannyg78
    Dannyg78
    4 Jan 2010
    100
    Thanks Received:
    Yorkshire
    Country:
    Ok guys here’s those codes are saying
    D.0 37
    D.40 71
    D.41 63
  2. Sponsored Links
  3. MeldrewsMate
    MeldrewsMate
    27 Jan 2010
    984
    Thanks Received:
    239
    Buckinghamshire, Darn Sarf
    Country:
    Turn the upstairs rads off, then see if the downstairs ones warm up.
  4. Dannyg78
    Dannyg78
    4 Jan 2010
    100
    Thanks Received:
    Yorkshire
    Country:
    Already tried that half do warm don’t go as hot as upstairs and only half warmed up.. maybe 5 of the 12 downstairs
  5. jackthom
    jackthom
    14 Feb 2007
    1,342
    Thanks Received:
    236
    Northumberland
    Country:
    Is there any microbore going to the downstairs radiators or are they all fed by 15mm pipe?
  6. Dannyg78
    Dannyg78
    4 Jan 2010
    100
    Thanks Received:
    Yorkshire
    Country:
    All 15mm
  7. jackthom
    jackthom
    14 Feb 2007
    1,342
    Thanks Received:
    236
    Northumberland
    Country:
    All lock shield valves open and no stuck thermostatic valves?
  8. Dannyg78
    Dannyg78
    4 Jan 2010
    100
    Thanks Received:
    Yorkshire
    Country:
    Yes jack all values are open and tvrs are good
  9. Jajodu
    Jajodu
    14 Apr 2017
    129
    Thanks Received:
    25
    Country:
    Try them one at a time downstairs, close valve's on the others and test individually.
  10. Sponsored Links
  11. ianmcd
    ianmcd
    15 Aug 2010
    21,903
    Thanks Received:
    8,610
    Lanarkshire
    Country:
    have you got a system by-pass fully open somewhere ?
  12. D_Hailsham
    D_Hailsham
    18 Oct 2007
    10,587
    Thanks Received:
    1,343
    Kent
    Country:
    That's an eight degree differential. The boiler is designed to work with a 20 degree differential. One of the reasons for this is the very high pressure loss across the heat exchanger when the flow rate is high, e.g with a small differential. Increasing the setting of the bypass by turning screw clockwise (1 turn = 10mb change).
  13. Razor900
    Razor900
    16 Nov 2007
    5,469
    Thanks Received:
    2,034
    Northamptonshire
    Country:
    Sounds like you may need a low loss header or other form of separation on the system.
    In the meantime try timing the hot water differently to the heating especially if there's no restrictor valve on the cylinder return.
    Or you may just have a weak pump in the boiler. Sounds like it has to work very hard
  14. Dannyg78
    Dannyg78
    4 Jan 2010
    100
    Thanks Received:
    Yorkshire
    Country:
    I’ve just discovered that the copper pipe leading outside from the boiler is dripping.. could this be a clue to why I have no circulation on the downstairs rads?
  15. Jajodu
    Jajodu
    14 Apr 2017
    129
    Thanks Received:
    25
    Country:
    What's the boiler pressure showing? The only cooper pipe exiting outside from the boiler would be the prv.
  16. Dannyg78
    Dannyg78
    4 Jan 2010
    100
    Thanks Received:
    Yorkshire
    Country:
    Pressure is showing 2bar while it’s running
  17. big-all
    big-all
    12 Jul 2004
    18,736
    Thanks Received:
    1,463
    Surrey
    Country:
    general comments
    probably not in the least applicable in your problem but may not help:D
    any radiator with a cover requires the thermostatic valve to be turned up perhaps 5 or 6 degrees to get a high enough amount off heat out to overcome the increased insulation off the cabinet along with the reduced airflow it causes
    this can be further hindered by furniture or curtains
    as soon as you said 3 story hot enough up stairs i off course thought open plan and hot air rises
    do you have open plan or many doors open ???
    try a close doors as you go regime to see what happens
    this problem can often be exasibated by a " conservatory " open to the down stairs firing heat through the roof faster than a machine gun :(
Loading...
Share This Page
