boiler problem
16 Feb 2012
I have a Glow worm boiler, not a combi but the other type.
Recently it stopped working so I called a engineer out and I was told that it was the PCB board which I replaced after checking the basics such as all fuses.
I bought a new PCB board and my engineer attempted to fit it but blew it at the same time. So after buy a new one he fitted it without blowing it and it worked.
For some reason now the boiler kicks in and then after 10 seconds it cuts out and the RESET & BURNER lights keep flashing and does nothing else. I have done the reset as it says, and it works and then cuts out after 10 seconds again and both lights flash again.
My engineer has said he has checked everything from the fan and the pressure switch but nothing.
If anyone could help me and my wife would really appreciate it.
Many thanks
Bob Pal
Pah! That's a simple one....Check the Dilythium crystals.
Good job that there are only two Glow Worm boilers otherwise we wouldn't have a clue which one you are on about..
Is the pump running and circulating? Which Glow worm model is it?
Its the other one, duh !
the one with the wotsits on
