helllo i've been having problems with my boiler ariston eurocombi sx 20 mffice it fires up fine when running hot water then when it starts to get hot it switches off and fires up again about 40 secs and repeats,same with the heating could you help.. mark
As chris said, had the same happen before pump running just abit too slow ,cleand pump and all ok but sludge could give the same prob either way a circulation problem. is it ok on a slow water flow rate ?
