- Joined
- 23 Mar 2021
- Messages
- 81
- Reaction score
- 1
- Country
Recently I have been getting full CH however hot water runs for a while , then goes warm then fires up again then gets hot for a few minutes and then does the same , ferroli boiler optima 901 , its been suggested that its the heat exchanger , however this morning Ive noticed that the boiler pump is really hot , ive taken off the small metal disc at the front and it is spinning freely. when the boiler fires up it does spin , I can hear it moving , i have a few questions about this .
if the pump isnt working would the central heating / water work at all as the pressure seems to be there?
if the pump is working why would it be getting hot? , it is really hot! , I have read that if its hot its not working but it does seem to be spinning ,
can I remove front of pump be removing the 4 fixings and examine it or would it be a nightmare to re assemble.
id appreciate any help .
Thank you.
Just an additional thing , water board turned water off 2 weeks ago due to new houses being built at top of road , as per normal when it came back on the water from the taps looked like coffee for the first 40 minutes! im sure this is related as no problems beforehand
Thank you.
