Boiler quote with only pictures
22 Jul 2017
Looks like the new way to give a boiler quote is by submitting images to the installer and he would then email a price.
So , a picture of the old boiler, outside wall with existing flue and airing cupboard, if appropriate.
Just wondered what the regulars thought about doing a quote this way?
Is it someone who lives quite far? Probably wanted to see if it’s worth their time without having to actually come round. I don’t blame as I usually get multiple quotes so that always means there’s a few who won’t get to do the work and if you multiple that by a lot of houses that’s a lot of wasted time.
Does the company start with a B ?
Check the small print...there are significant clauses to cover all the extras that won't be found with this method of quoting.
why not just get some quotes from recommended local installers, I for one would never quote via photos
Ok, those r all fair comments but has had good online reviews.........if that means anything.
Also the quote has said that I may need a condensate pump, I know what the condensate pipe is but under what circumstances would u need a pump
If there is no natural fall to a drain or the outside, e.g. it has to go "up and over". It may just be standard terms, a "just in case", if they are not visiting to quote.
Ok thanks, it will just go from the boiler down and connect to a soil pipe a couple of feet away.
