Hi again,
I posted a topic a few days ago regarding my Ferroli boiler as per below:
“I have a gravity fed gas boiler with four 1 inch feed pipes. Two which feed the radiators and two which feed the hot water system. Although old, the boiler has worked fine up until now...
Now however, every time the pump winds down it sends a surge of boiling water from what appears to be the boiler all the way through the hot water pipe, through the hot water cylinder (located in bathroom) and then up to the expansion tank in the attic. When this happens, the pipes make an almighty racket and physically contract under the pressure/ heat. This last for a few seconds every time the pump switches itself off
One second you can have your hand on the hot water feed pipe and the next second it is literally too hot to touch and then cools down almost as instantly – making some very laud scraping, moaning, banging noises.
I have been up to the attic and the expansion tank, although not overflowing is very hot.”
It was suggested that the problem relates to either my boiler stat or my pump over run stat so I guess my next question is:
1) Where is the pump over run stat and where is the boiler stat?
2) How can I be sure it is one of these i.e. how will I know if they are broken, is there a test I can do?
3) Do I need to call a boiler repair man to replace either or, or could my farther in law who is an industrial pipe fitter fix it i.e. not much work needed to the internals?
Cheers
Cheers
