Thanks for reading my post.
My central heating system has developed a problem and I need some guidance if I may, as follows:
I have a gravity fed gas boiler with four 1 inch feed pipes. Two which feed the radiators and two which feed the hot water system. Although old, the boiler has worked fine up until now...
Now however, every time the pump winds down it sends a surge of boiling water from what appears to be the boiler all the way through the hot water pipe, through the hot water cylinder (located in bathroom) and then up to the expansion tank in the attic. When this happens, the pipes make an almighty racket and physically contract under the pressure/ heat. This last for a few seconds every time the pump switches itself off
One second you can have your hand on the hot water feed pipe and the next second it is literally too hot to touch and then cools down almost as instantly – making some very laud scraping, moaning, banging noises.
I have been up to the attic and the expansion tank, although not overflowing is very hot.
Does anyone have any ideas what is happening before I call a plumber?
If you need any more information please let me know.
Cheers
Cheers
