Hi
have Worcester boiler 4 years old that trips the 3amp fuse but only when a working room temp sender box is fitted. Story is we had boiler issues with condensate pipe which has all been repaired but meant that the 3amp spur and the sender (Honeywell bdr91) got wet. Boiler put backinto full working order, will stay on for hot water and can push the heating boost button (man with ladder) that runs for 15 mins all without any problem as long as broken sender unit is installed (so obviously no heating as no call signal)
replaced the front of the sender unit with exactly the same type and everything worked for about 30mins then bang. Reinstalled broken sender unit and New fuse fitted this morning and boiler back on with no issue with hot water and boost function running Heating (15 min cycle).
So my question is what reading should I get from the sender unit wiring any ideas what to do so I don’t blow another 70 quid unit. Is it likely something shorting to earth and if so why take half an hour to blow? It looks like it’s probably blown the board in the sender again as there is a black mark on the 240v side of the sender unit.
Hopefully this is something simple I can sort so any help appreciated otherwise will get them to send a leccy to sort next week. Obviously I know I cannot open boiler so it’s what I can check at switch, thanks
