Boiler wet part quesition....
5 Oct 2008
Bournemouth
Hello all
What's the best way to replace a "wet" part in a boiler? I have heard that closing the boiler isolation valves can be troublesome with leaks on re-opening. Is it best to drain down the whole primary circuit or is it best to close all radiators and drain just the pipework?
Thanks for your advice, all the best.
depends what the part is really. some parts you can get away wih just dropping the pressure of at a drain point on the blr and some parts meed draining- experience is the thing here.
ps I don't want to start another is it /isn't it debate. But my understanding of the gas safety regs is that any work on a gas appliance constitutes working on a gas fitting, regardless of whether you are only working on the water side or not.
I appreciate all of your replies
As it is just 1 single open point I will just drop boiler pressure and replace it. But if it was a pump head etc with more then I'd drain down more to below boiler level.
