my valiant boiler keeps tripping out the electrics when being turned on, is this a faulty pump. the boiler model is turbo max plus 824e. also it does not heat up hot watere when the heating is on.
Most likely cause is a faulty pump, but without proper checks this can't be confirmed. Same problem with the hot water, without further information its hard to say whats wrong.
More than likely a divertor fault with the hot water though
