Another day, another problem with my Boilermate!
I have seen other similar issues to mine, but wanted to check with the forum before attempting the repair.
Issue: DHW goes cold after running tap/shower for 5-6 mins, this lasts 10-20s and then come back hot and around the cycle again.
There are no errors on the sensors and they seem to respond to what is happening at the taps. The store is at full temperature (77 degrees) and remain there during these issues.
This happens at all taps, DHW pump is set to 3 and seems to be spinning freely. System has been on and off many times and all sensor cable contacts have been reseated.
Measured voltage across pump, hit a max of 170V (should this be 240V?) . When the hot water fails, the pump stops, voltage = 0 V
The PHE temperature sensor reads 54-55 when the pump stops. DHW temperature senor only seems to get to about 48 max.
My guess is that the PHE is scaled up, as the PHE temperature should be less than 55 degrees. This is causing the pump to stop and only starts up when PHE temperature drops again.
I was wondering if any knows how the DHW temperature is actually controlled or what is really causing the pump to stop. Not sure if voltage at pump is linked to PHE temperature or DHW temperature or both.
Additionally, the PCB does buzz during the hot water demand, this might be part of the issue.
I have a British Gas homecare plan, but with £50 excess. The plan was to try and descale the PHE and see if there is any improvement. If so, replace at next convienient opportunity. If not, get BG in to start replacing PCBs and/or temperature sensors.
There are some very knowledgable people on here about these systems, so I was hoping for some input based on my findings.
I have read many posts on different forums and it seems that scale may be the issue
