    Dismiss Notice
Boiler's not working F.75 just comes up any ideas
Discussion in 'Plumbing and Central Heating' started by cryan1974, 4 Feb 2011.
  1. cryan1974
    cryan1974
    4 Feb 2011
    Thanks Received:
    Liverpool
    Country:
    system won't egnite, got no heating or hot water. F75 just keeps coming up
  2. Sponsored Links
  3. Agile
    Agile
    26 Jun 2004
    64,039
    Thanks Received:
    4,595
    London
    Country:
    Youn dont even bother to tell us that its a Vaillant ! Do you think that we are clairvoyant?
    As the forum advice suggests you will see so many previous posts covering this fault!
    There are several possible causes.
    Start by pressurising to 1.5 Bar.
    Tony
  4. Bunnyman
    Bunnyman
    22 Mar 2010
    5,497
    Thanks Received:
    1,841
    Northamptonshire
    Country:
    Usually pump pressure switch but maybe pump
  5. Boilerman2
    Boilerman2
    10 Jun 2009
    5,225
    Thanks Received:
    1,015
    Suffolk
    Country:
    Very common Vaillant fault try a new Pump pressure sensor! ;)
  6. dreadnoughtheating
    dreadnoughtheating
    31 May 2009
    3,694
    Thanks Received:
    791
    Norfolk
    Country:
    Yeah, so its a Vaillant, but has anyone suggested he checks the pressure gauge to make sure the needle is in the lower section of the grey zone first?
    (or, indeed looks in the book that we all leave in the boiler compartment ;) )
    DH
    EDIT, edit, edit. Tony did :rolleyes:
  7. combispecialist
    combispecialist
    4 Mar 2010
    271
    Thanks Received:
    35
    Lincolnshire
    Country:
    how bigs the system????it may need another expansion vessel fitting or vaillant do an "f75" kit for intermittant issues
  8. gas4you
    gas4you
    23 Feb 2007
    21,178
    Thanks Received:
    1,912
    Norfolk
    Country:
    Probably just crap in the pump pressure sensor.
    Just remove and clean it out ;)
  9. Sponsored Links
  10. Bunnyman
    Bunnyman
    22 Mar 2010
    5,497
    Thanks Received:
    1,841
    Northamptonshire
    Country:
    Dreadnought totally irrelevant where pressure gauge is on f75 fault
  11. dreadnoughtheating
    dreadnoughtheating
    31 May 2009
    3,694
    Thanks Received:
    791
    Norfolk
    Country:
    Bunnyman, can only say that last F75 fault I attended, a quick burst up to 1.2 bar (on the guage, not using - button) has lasted 2 months. Maybe I, and customer, got lucky?
    take your point though.
    DH
  12. Bunnyman
    Bunnyman
    22 Mar 2010
    5,497
    Thanks Received:
    1,841
    Northamptonshire
    Country:
    Push in pressure up can get em workin but usually luck! If u drain boiler then switch on an press the minus button,if digital display reads above 0.2 u know sensor is knackered or blocked,only £20 anyway.also u can check when boiler is pressurised , just turn boiler off an hold minus in and turn back on ,it will show pressure reading then when pump kicks in display should go up at least 0.2
  13. dreadnoughtheating
    dreadnoughtheating
    31 May 2009
    3,694
    Thanks Received:
    791
    Norfolk
    Country:
    Thanks for that BunnyMan, I can guess from this reply and your others in the CC, that you must look at a heck of a lot more Vaillants than I do ...
    DH
  14. Bunnyman
    Bunnyman
    22 Mar 2010
    5,497
    Thanks Received:
    1,841
    Northamptonshire
    Country:
    I am afraid it's all I know! Lol!
  15. Agile
    Agile
    26 Jun 2004
    64,039
    Thanks Received:
    4,595
    London
    Country:
    If its not convenient for me to go immediately I usually find getting the customer to increase pressure will get it going for a few days.
    I also find EXV pressure needs to be correct to avoid F75.
    Tony
  16. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
