Boliermate 11 leaking on 2 PCB boards
29 May 2010
Derby
I m having problems with my Boilermate 2 its leaked and the water has dripped behind the cover and over the electronics PCB and wiring i turn on the boiler and the fuse goes, so i m thinking it s the boards which have gone..... If i need to get a new board (s) just wondered where i can get them from??
Thanks in advance
the leak will be from the cold feed or open vent washers.
dry the boards out with a hairdryer, they will probably work again when they are completely dry. make sure to get right underneath any plugs on the board as that is where the short will be.
Thanks people, i ve tried drying PCB briefly with a hair dryer then tried again but blew thw fuse. My Mate who's a plummer is going to sort the pipes out just need to get the circuit boards if they don t dry out......
