Never used befor, When would this be used Seen it mentioned in another post regarding a backing for skirting boards if the plaster beneath has pulled away? Is it the same as Hardwall?
This is the official version; http://www.british-gypsum.com/produ..._undercoat_plasters/thistle_bonding_coat.aspx
but it’s also good for patching & binding old scabby walls, where the skirting has pulled the base coat off (as youve seen), to fill over steel/plastic cable capping after a re-wire, as an initially base coating to fill out heavy Artex patterns prior to skimming; best for low suction backgrounds & patching but can also be used on high suction backgrounds with the right prep. Is quiet soft when set.
Thanks for that Richard, no I haven't anything in mind, but being a newby to plastering I still have a lot to learn. At the present time my jobs have been straight forward.
