I'm fitting a new bathroom in a different room. I intend to fit a towel rail style radiator. The pipes will go under the floor then be chased into the wall. I will be using solder fittings.
I've bonded all the copper pipes, fittings etc with 6mm earth cable and run a bit to where the radiator pipes will be. will I be alright bonding to the copper pipes under the floor, or does it need to be able to be inspected ? (if so then will a removeable floorboard in the corner be acceptable ?).
