Border tiles and corners
23 Jun 2009
Gloucestershire
Hi, i have a problem with border tiling and internal and external corners
my choosen border tiles have a large bevel on the top edge, approx 1.5 cm radius semi circle. this means that i can't butt join the tiles in the corners as i have done else where as they leave a gap.
how do i cut the tiles, mitre them, to fit on the corners? my cutter just appears to do flat cuts.
Ali
Ali
MITRED, what type of cutter do you have, if its electric it should have a mitring guide, if not you could use a grinder with diamond tipped blade and a tile file.
