Hi, our Bosch washing machine (WFO2867GB/01 FD - 8505 600573)tripped the RCD a couple of times, and eventually got through the cycle but the drum hadn't turned.
I read through all of the postings here and changed the brushes, which were down to about 10mm, but it made no difference. I then emptied the filter, which did have some coins and a bra wire, but I couldn't see if it had been stopping the pump, although the pump had been emptying the water so I don't think so.
I found another website which recommended blowing down the pressure tube, but that wasn't blocked.
I saw somewhere about 3 'pairs' of terminals to be checked, but my motor connector has 8, only 7 of which are connected on the terminal block, what should I check on here?
A local repair firm say it sounds like a new motor, which isn't worth the repair.
Any ideas?
any advice gratefully received.
Any ideas?
