Bosch Classixx Condenser Tumble Dryer WTE84107GB
30 Mar 2011
Hertfordshire
Hi all,
Anyone know anything about these?
Ours just flashes the Start/Stop light & does nothing else.
Won't run any cycles or anything.
Just flashes the Start/Stop light.
I have had it apart & re-seated all the connections inside.
Also had the back off & tried the red reset button, just incase it was that, but it didn't really click & has not solved the problem.
Anyone have any other ideas I can try.
Many thanks,
Pete
30 Mar 2011
Hertfordshire
Hi all,
Just to let you know, it is now fixed.
I took the left-hand side (as you look at it front on) off the dryer & took the plastic shield off the pump.
One of the connectors had risen a bit.
When I pushed on it, it went down about 5mm.
I also cleaned some grey fluff from inside part of door & underneath the door moulding inside the machine.
Put it all back together.
Switched it on, then to cupboard dry.
The Start light came on much quicker than it was.
I pushed the Start button & it started to spin as normal.
Maybe this will help others if they have similar problems.
Thanks again,
Pete
