    Dismiss Notice
Bosch dishwasher fog horn noise
Discussion in 'Appliances' started by duzu, 19 Jun 2019.
  1. duzu
    duzu
    19 Sep 2013
    9
    Thanks Received:
    Surrey
    Country:
    I've recently had to take my Bosch dishwasher apart to replace the heater element assembly. This involved disconnecting and refitting the sump assembly, circulation motor, drain pump, some internal piping etc.
    The dishwasher now works fine however every now and then it makes a moan similar to the sound of a fog horn. I've uploaded a recording here: https://instaud.io/3PZC
    Any ideas what could be causing this?
  2. blup
    blup
    5 Nov 2007
    997
    Thanks Received:
    143
    Country:
    How old is the machine?
    Does the noise happen when the dishwasher is under load e.g draining or pumping?
    Blup
  3. Sponsored Links
  4. duzu
    duzu
    19 Sep 2013
    9
    Thanks Received:
    Surrey
    Country:
    The machine is abour 10 years old.
    Yes, the sound comes when it is circulating water but not immediately when it starts circulating. You can heat water circulating both before, during and after the noise.
  5. jj4091
    jj4091
    1 Dec 2006
    4,585
    Thanks Received:
    385
    Cumbria
    Country:
    I can't hear anything in your recording, but not having isolator valves or stop taps fully open can cause some strange noises due to water flow.
  6. Sponsored Links
  7. blup
    blup
    5 Nov 2007
    997
    Thanks Received:
    143
    Country:
    Maybe when refitting the pump and motor some damage occurred to one or the other, or the circuit connections.
    Blup
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
