Hiya
Had a look through the forums for an answer to this and there is a lot of info but just wanted to run this past you guys first.
I think this is a common issue but hear me out! My Bosch Classixx was not heating the water, or filling up very well or drying at all and was getting stuck on '1 minute' at the end of its cycle. I've had a look on here and firstly tried the "tip to the left" trick which didnt seem to work.
So im left with from what i gather, either a dry solder joint on the PCB or to clean out some of the internal tubing as per some photos i saw on here. I'm no expert but im happy to give things a go before i need to pay someone.
However, today I tried it one last time before opening the machine up and hey presto it ran a full hot wash cycle perfectly. Loads of hot water, hot air and finished on zero.
But since trying again it has reverted to the initial problems. Though, sometimes it starts to work perfectly, filling up with water but then 20 minutes into the cycle or so, it reverts back to its cold water minimal filling etc etc...
So, the fact that the fault sometimes fixes itself, does that mean it cant be a dry solder joint? I guess i just want to know what i shoud try first so that i dont start taking out PCBs if its not entirely necessary.
Any advice appreciated....
Bobby.
Bobby.
