    Dismiss Notice
Bosch Dishwasher SMS50E06UK/01 Fault
Discussion in 'Appliances' started by DWSE01, 8 Oct 2011.
  1. DWSE01
    DWSE01
    24 Aug 2011
    6
    Thanks Received:
    Aberdeenshire
    Country:
    I have a Bosch dishwasher model number SMS50E06UK/01 which has an intermittent fault and a code is displayed on the control panel. The code is E14 and appears at the beginning of the intensive wash cycle. :D
  2. zipper
    zipper
    20 Nov 2009
    2,789
    Thanks Received:
    505
    Aberdeen
    Country:
    This usually ends up being a flow meter issue. Remove the LH side-plate & look for a small electronic card mounted near the bottom of the plastic water tank.
    Take out the small plug to it & re-seat it again (if necessary give it a slight nip to tighten it up).
  3. DWSE01
    DWSE01
    24 Aug 2011
    6
    Thanks Received:
    Aberdeenshire
    Country:
    Thanks zipper for the help…..I did suspect that it may be the flow meter as after watching the dishwasher for almost an hour no E14 fault appeared. Where can I find fault codes for new range Bosch equipment?
  4. zipper
    zipper
    20 Nov 2009
    2,789
    Thanks Received:
    505
    Aberdeen
    Country:
    You ought to be able to dig up some info on Bosch error codes by using the search function. If you can't find what you are looking for get back to me.
  5. DWSE01
    DWSE01
    24 Aug 2011
    6
    Thanks Received:
    Aberdeenshire
    Country:
    I have access to their web site spares search if that’s what you mean but it has limited info I thought.
  6. zipper
    zipper
    20 Nov 2009
    2,789
    Thanks Received:
    505
    Aberdeen
    Country:
    I meant the search function on this site. You won't find much error code info on the Bosch website (manufacturer error info tends to be all terribly hush-hush secret stuff).
    Have a wander through the appliance section, the chances are that will come across something there.
Loading...
Share This Page
