For some reason my Bosch Dishwasher has stopped working properly.
Main fault is that it will reach the end of the programme but not switch off as water flows in and the drain pump keeps attempting to drain the machines. Clean water will sit in the bottom of the machine
I looked at other posts in the forum and have attempted to fix following that.
I have cleaned the float valve and checked the impeller and non return valve but still no joy.
When the machine is running i can hear the drain pump kicking in and then there is clean water running through the matrix. As a result the water never gets a chance to heat up and the cycle persists.
The Matrix
Float valve assembly
There is one way to make the water stop flowing in by using the red rod in the picture to trip the switch and cut off the water inlet pump. Then the machine kicks in as normal. Not sure whether the water in the base of the machine is just not reaching sufficient height to cut off the incoming water pump. As soon as I release it it allows the inlet pump to kick back in and we get back into the same problem again.
There are no leaks in the machine.
Its a Bosch Exxcel model SGS43E08GB/43 FD8310
Heres hoping someone can help.[/img]
The Matrix
