Bosch drill with broken chuck - help!
20 Jul 2015
Hi All,
I have a Bosch PSB 500 RE drill, I need to change the Chuck, as the chuck is broken and difficult to tighten or loosen, since its a keyless chuck and there's no screw in side the chuck to remove, tried to put the drill in reverse mode and an Allen key in the Chuck but it still spins round and I can't UNDO IT !!!! - HELP
Might be the case that you can't remove the chuck, it could be heat shrunk onto the shaft. Failing that I suppose it could be held in place with a taper.
Are you sure it hasn't got a torx screw inside ? Could also be left hand thread. I got one off once by clamping an allen key in the chuck and hitting the long arm of it with a hammer. Again it might be left hand thread
Not worth the effort really is it? Screwfix will sell you a more powerful (710W) drill for £19.99. Bet you can't buy a Bosch-compatible keyless chuck for that...
There's likely to be a screw in there somewhere if it's a reversible drill. Give it a good clean and see, it will be left-handed.
'more powerful', it's not just about the number of supposed watts.
Chucks cost less than half that.
