Bosch exxcel auto option dishwasher
13 Jun 2010
Essex
We were given this dishwasher about a year ago and has been working fine but now has stopped pumping out the water when the cycle is finished. Not got a manual so am stuck on where to look for the problem.
Numbers inside the door
Type S9G1B
013090230827013867
E-NR
SGS43E02GB/43
FD8309
001386
Any one got any ideas please?
Wife keeps moaning about the washing up bowl!!!!!!!!!!!!!!
Take out & inspect the filters first. Then bail out as much water as you can & look in the sump. On the left hand side you'll see a small plastic cover held in place with a screw. Take this off & you should see the pump impellor. Check to see if there is a piece of broken glass or crockery jamming it.
You can download a user manual here http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
Thanks for the reply - I've just checked the impellor and its fine slight resistence but nothing stopping it from turning - nothing in the bottom chamber.
Have got the side panel off and just done a pre rinse cycle. If I pull the red float bar up the pump inside spins round - but no water comes out.
Cheers
The red float bar you refer to is part of the antiflood protection, the pump is supposed to run when this is lifted. Rather than type everything out again check out this thread a few posts down. //www.diynot.com/forums/viewtopic.php?t=228861 Read the bits regarding cleaning of pipes etc. Also check to see if the non-return flap isn't stuck in the sump drain outlet.
BTW are you sure your plumbing is in order?
Have tried fiddling with the red float chamber and it seems to have cleared the problem - maybe it was just stuck - have done a couple of pre rinse cycles and all seems to be working fine - fingers crossed.
I only came across this site after looking for help for the dishwasher - what a brilliant site!
I would like to say a BIG thank you for all your help. Now to look at the washing machine!!!!!!!!!!!!!!!!!
