I have a bosch built-in double oven. I removed the door from the lower (larger) oven following the instructions. The door was replaced without problem....however....it no longer closes tight to the oven body.
The result is loss of heat and increased noise (it's a fan oven). I've looked and can see no way to make the door fit tight as it originally did.
There is no damage to the door or the hinge that I can see.
The door "falls away" from the body by about 3-5mm at the top.
There is no damage to the seals.
There is no "debris" in the base stopping the door.
There is a screw beside the hinge on the door - these have NOT been touched - do they simply retain the cover?
Any help welcomed!
Regards
h4orth
Any help welcomed!
Regards
h4orth
