ok. This is driving me potty. It doesn't happen all the time, only about once in every three washes or so.
Machine will wash ok and then go onto rinse cycle. However, it will not then switch to spin. The countdown will go down to 0:01 and the machine continually agitates. It sounds like it wants to switch but doesn't.
I then switch off the machine. I put it straight onto a drain or spin cycle, but nothing happens - it just hums. I have even left the machine switched off for half an hour or so before putting onto drain or spin cycle - but again nothing happens. Even tried putting the machine onto a quick wash cycle - nothing.
The only way to get round the problem, is to manually drain the machine through the emergency hose at the front, then remove the filter, thus releasing the excess water in there (the filter is always clear and the impeller rotates). Then switch the machine on, put straight onto a spin cycle and hey presto, we are up and running.
The next 2 or 3 loads work fine, before the problem happens again. It does not seem to correlate to any particular wash setting.
Please help. I hate washing machines at the best of times.......
