Bosch WFL2260 will only fill on 30 degree programme
17 Mar 2008
Help! My Bosch washer has decided to become environmentally friendly, and will only fill if it is on the 30 degree programme. All other programmes, it makes a humming noise but no water is taken in, not even on the cold wash. Any ideas? :confused:
30 degree wash is cold fill,all others take hot first then cold,your hot water is turned off.
Thank you Assuhors :D My husband had switched a particluar valve off in order to install a new sink and tap in the jitchen, and he hadn't switched it back on properly... So thanks very much, you were quite right! :D
