- Joined
- 4 Feb 2015
- Messages
- 2
- Reaction score
- 0
- Country
My Bosch Exxcel Dishwasher started making a whining noise when the sprayers are working. Before the main wash cycle there is a lot of clicking from within the unit.
I am not sure if it is the motor/impellor or a relay. The pump pressure is low, and although the whining noise is recent, the clicking noises have been around for a while.
I have had the unit apart, and stupidly, just had a quick look inside impellor, the motor appeared to turn, but I did not really closely inspect the ability to rotate of the motor and impellor.
Unit is E nr. SRS46A02GB/08
And there is a you tube clip.
http://youtu.be/xmH9NZB6t_A
Is it worth getting the impellor kit, I read if the spacer is failed, the impellor will rub against housing. I have also heard motor failures are often incorrectly diagnosed when it is the impellor.
All ideas welcome thank you
L
L
