    Dismiss Notice
bottle trap won't seal
Discussion in 'Plumbing and Central Heating' started by crooner, 9 Oct 2014.
  1. crooner
    crooner
    15 Jan 2010
    162
    Thanks Received:
    2
    Glasgow
    Country:
    hi all , bought a 32 mm bottle trap for my new vanity basin ,
    the waste is one of those pop up jobs, anyway the bottle keeps leaking out of the thin rubber washer on the top of the bottle trap ,
    any suggestions appreciated
  2. Sponsored Links
  3. Are you sure it's not leaking down the threads of the waste?
    • Thanks Thanks x 1
  4. crooner
    crooner
    15 Jan 2010
    162
    Thanks Received:
    2
    Glasgow
    Country:
    no, it's coming from the top bottle connection thanks
  5. crooner
    crooner
    15 Jan 2010
    162
    Thanks Received:
    2
    Glasgow
    Country:
    also it only leaks when it's draining
  6. Are you sure that there is enough space for the backnut on the trap to fully tighten - it's not reaching the backnut on the waste is it?
    Make sure that the neck of the trap sits inside the waste and that the washer is seated against the flange of the trap before tightening up the backnut
    If that fails then either replace the washer/o ring or get another trap
    If the leak is below the backnut then it's the trap if it's above the backnut then it's usually the waste
    • Thanks Thanks x 1
  7. Markerpen
    Markerpen
    30 Nov 2012
    33
    Thanks Received:
    3
    Surrey
    Country:
    I'd go with newboy's suggestion. Quite a few times I've had to cut 3mm or so off the nut on the trap. It seems that these pop up wastes have very short threads.
    • Thanks Thanks x 1
  8. crooner
    crooner
    15 Jan 2010
    162
    Thanks Received:
    2
    Glasgow
    Country:
    this photo might help
  9. Plenty of space there then!
    Wind the backnut off
    Check that the seal is square and intact
    Make sure that the top of the trap sits inside the waste
    Hold in position
    tighten backnut
    • Thanks Thanks x 1
  10. Sponsored Links
  11. crooner
    crooner
    15 Jan 2010
    162
    Thanks Received:
    2
    Glasgow
    Country:
    already done all those checks , thanks newboy ,
    i'll get trap changed tomorrow & see if that helps
  12. How did you get on with the bath waste?
    • Thanks Thanks x 1
  13. PotatoHead
    PotatoHead
    5 Jul 2010
    65
    Thanks Received:
    12
    Manchester
    Country:
    If I'm not mistaken that looks to be a cheapie screwfix or similar. I've tried them on a couple of occasions and they can be buggers to seal.
    Go out and buy a McAlpine one and you will have no problems.
    • Thanks Thanks x 2
  14. Hugh Jaleak
    Hugh Jaleak
    3 Feb 2008
    7,181
    Thanks Received:
    1,679
    Northamptonshire
    Country:
    I'll second that. The cheap S/fix traps are often carp, I've had several that wouldn't seal for toffee, swapped for McAlpine equivalent and that sealed first time!
    • Thanks Thanks x 1
  15. PotatoHead
    PotatoHead
    5 Jul 2010
    65
    Thanks Received:
    12
    Manchester
    Country:
    I rememeber taking one back as the nut pulled of the trap body with minor pressure. Asked if they had many problems with these traps and the chap said no never. Minute later as they are still serving me another man comes in with the exact same trap with the exact same problem :mrgreen:
    • Thanks Thanks x 1
    • Like Like x 1
  16. Hugh Jaleak
    Hugh Jaleak
    3 Feb 2008
    7,181
    Thanks Received:
    1,679
    Northamptonshire
    Country:
    They tightened, but whatever I did, I simply couldn't get it to seal. I wasn't resorting to PTFE with brand new waste and trap, shouldn't have to. Didn't mess about 2nd time, trap went straight back and got changed! I've not bought the cheap ones since. ;)
    • Thanks Thanks x 1
  17. Agreed - I think they're branded as "Floplast" and I stopped using them for the same reason.
    If you look at the screwfix website a significant number of reviewers post the same problems
    • Thanks Thanks x 1
    • Like Like x 1
Loading...
Share This Page
