box cutting problem
28 Aug 2013
Yorkshire
Hi all, this is my first post here and i'm not entirely sure if this needs to be in the building section or electrics. Anyway, I attempted to cut the box holes for some new socketss the other day and all did not go to plan. It is a brick wall with approx 20mm of plaster covering it. I started to drill around the edge of the marked box to the correct depth (37mm ish) when all of a sudden the drill went straight through! i thought it must have been a join so i kept going. Anyway, i have since found out that the bricks have been layed frog down and obviously there is no mortar in the frog thus causing my drill to go straight through. I am just wondering what i should do now? The recess is still not deep enough (just short of 25mm) and i have another one to do on the same wall and some chasing. Any help greatly appreciated :)
You would have the same problem if the frog was at the top,depending where you drill. Cut your recess and fill any large holes with a bit of mortar and the bits of brick you have chopped out.
you are correct. it's just the fact there is no mortar in it that worried me. I'll go for it then and fill the hole with mortar. cheers :D
