If you're going to tile over the "pipe boxing" in your bathroom, just use plasterboard, for all you'll need... 9mm or 12.5mm, plain or moisture resistant,,,, either.... Different if it was the bath/shower areas..... Once you've tiled and grouted the boxing,,, run a bead of silicone down any internal corners to give it a neat finish.
Roughcaster.
