I'm in the process of carrying out a loft conversion and have found that I have very limited space to box in a multitude of cables that are running the length of the loft. At the moment the cables are just lying in between the rafters under the loft insulation right next to a wall. There is just about enough slack to move them but it means that I will heave to have 'tie' them all together. There are 2 x 1.0mm T&E, 1 x 6mm T&E, 2 x co-ax cables and 2 x 2.5mm T&E cables which I intend to somehow box in behind plasterboard. My question is: is it acceptable to run all these cables together whether it is in some sort of trunking or by bunching them together and somehow 'squeezing' them into the limited space that I've got?
