Have refurbishing my bathroom. Putting in new Architeckt Concealed Thermostatic Shower mixer. The hot and cold connections are supplied with olive and compression nut.
As old shower was 22mm connections this one is 15mm, I propose keeping the 22mm pipework to within 10inches then join by conversion down to 15mm. As space is tight it would really help if this conversion and subsequent connection was done with braided flexible tap connectors. The old and new pipes dont line up exactly.
It is a gravity fed shower, can I use these flexible pipes, it will save chopping too much wall through to airing cupboard. As always many thanks in advance, you are all gradually rebuilding my plumbing and central heating systems!
