We've had 3 of our existing radiators start to leak over the last month, and I suspect more to start leaking soon (if they're representative of the lot). They're all about 15 years old, so have had a good run (I guess?). The 3 that have started failing are all leaking from the same place - they've rusted around the welded joint that connects to the actual panel, and are slowly dripping from there. The system has always had inhibitor in place, and a few years ago that was flushed and renewed when I had a new boiler fitted... They were cheapo radiators though - "Heatline", maybe? I can't remember, and there's no info on them.
Anyway, I'd like to replace all of them - they're all either type 21 or type 22, all 400mm tall (which I need to stick to) with widths between 400mm and 1600mm.
What's generally considered a good mild steel radiator brand these days?
Thanks!
Thanks!
