Brass fitting required
15 Dec 2009
Whitby N Yorks
I need a fitting for a pressure washer. Brass, alloy or stainless.
The fitting will be male/male
M22 to M14 (reducer)
The M22 is the common pressure washer high pressure hose connector and I understand is a fine thread pitch (1.5mm)
The M14 needs to be a coarse pitch (2mm)
Advice much appreciated.
Mike
Most brass plumbing fittings are BSP threaded, and tend to be imperial sized. Metrix sized finer pitched threads are only found on smaller metal to metal fittings like tap tails etc
Even then though a 14mm (M14) fitting is not a usual size of plumbing fitting either.
