Silverline pressure washer 2100w 165bar question
15 Dec 2009
Whitby N Yorks
I have recently bought the above pressure washer and would like to fit a better and longer high pressure hose instead of the horrible one wound round the spool at the top. Additionally I would like to remove the top hose spool and have the high pressure hose connection at the base of the machine opposite to the water inlet (same as the Silverline 1400w 105bar model which I also have).
I have looked for a workshop manual online with no luck and wondered if anyone knows what fitting I will need to connect the high pressure hose at the base.
The high pressure hose I have has a m22 female connector so one end of the new fitting needs to be m22 male, just need to know what the other end needs to be? Maybe a bit of a shot in the dark but one never knows!.
Mike
A few years ago now, but I managed to suffer the wand of my Lidl pressure washer seizing up. Lidl's supplier wanted silly money for a replacement, but I found a knowledgeable supplier on ebay, who was familiar with many of the fittings, was able to supply a wand and at a fraction of the cost.
Silverline is just a badge name, try to work out the actual manufacturers name, as a starting point.
