My question is similar to this one I found:
http://www.diynot.com/forums/viewtopic.php?t=36208&highlight=hob
but there was no conclusion.
I have an elecric oven and gas hob, and want to replace the gas hob with an electric one.
+ Current the single oven is on a 32A breaker. The oven is being replaced with a double oven that suggests a 40A breaker.
+ The new hob is 6.3 KW.
+ I'm am not sure of the wiring used for the existing oven so plan on replacing it with 6mm wire rated to 12 KW to ensure it is correct. The new wire is stated as being suitable for ovens and showers.
+ The oven and hob will be within 2 meters of the switch. The switch as it happens is also within 2 meters of the breaker.
Now if I have both ovens and all four hob rings on by my calculation I will have just over 12 KW so a 50A breaker is on the limit.
Questions:
+ Can I have both cooker and hob on the same wire from the same switch and to the same breaker? Previous questions/answers on this forum seem to suggest yes but it seems marginal to me.
+ What size breaker should I use? Is it ok to have a 50A breaker if I only have the oven on and not the hob?
Thanks for any advise.
Questions:
