Hi, about to install a 1600mm x 900 breakfast bar coming out at 90degrees to the wall.
First 300mm is open shelving that I’m making from an end panel, then 600 integrated washing machine, then 600 integrated drier.
Breakfast bar panel behind appliances and returned on the end of the appliances. Granite worktop to be installed after.
What’s the best way to support the granite and also to install the appliances? Build a cls frame behind the appliances and angle bracket end panels to the frame and floor between appliances?
