Hi all,
I recently pulled down our garage in order to reclaim the garden and am now left with a fiendish 24ft x 10ft x 6" thick slab of concrete to break up and remove.
I bought an 18kg breaker having been advised it would be up to the task. I've just had a go and progress is demoralisingly slow. I've done maybe a square foot in about half an hour.
The concrete I'm dealing with has stones / hardcore mixed in with it. Is that normal and should the breaker be able to deal with it? The chisel is starting to look blunt already!
The breaker came with a flat and a point chisel. I've been using the flat one so far. Under what circumstances should I use one or the other?
Is there a "proper" technique? I mean, should I be chipping away a sliver at a time, inch by inch, or should I try and carve out a decent sized slab and prise it up?
Any pointers would be greatfully received... Perhaps it's just the wrong tool for the job and I should hire something more heavy duty?
Thanks,
Rob
Thanks,
Rob
