Welcome advice required,
Going to install 4 brick lights to a conservatory base as it is built, here's the plan.
(i) Chop in a 5A unswitched fuse spur fed by the ring main at socket height (can't pick the lighting circuit )
(ii) From here run to a plate switch
(iii) From the switch to the lights in 1.0mm t&e run in the cavity of the dwalf walls, in series.
Has anybody installed these lights/know a quick fix
