Brick Lights for Conservatory
4 Nov 2004
Welcome advice required,
Going to install 4 brick lights to a conservatory base as it is built, here's the plan.
(i) Chop in a 5A unswitched fuse spur fed by the ring main at socket height (can't pick the lighting circuit )
(ii) From here run to a plate switch
(iii) From the switch to the lights in 1.0mm t&e run in the cavity of the dwalf walls, in series.
Has anybody installed these lights/know a quick fix :?:
he means take a wire from one to the next to the next, with each light connected to live and neutral as it goes past. You could run a separate wire from switch to each lamp, but only if it is easier than looping from one to the next.
there is a pic of that in the for refernce (one day i will spell that right)
