Hello all,
I am brand new to this and just wanted some advice on fixing plasterboards to a bathroom wall.
The room has recently been stripped. Three walls are now back to joists, I am going to screw new plasterboards to this, with the dark side out, for skimming by a professional later.
The exterior wall is a non cavity wall, and is now back to the bricks. There are two windows on the wall, which are to remain in place.
As it stands, this is the plan...
1. Apply a layer of browning straight onto the bricks then wait until dry
2. Use dot and dab with Dry Wall Adhesive to fix plasterboards to the browning on wall with dark side out for skimming later.
Any advice on how much adhesive to use? Should I use insulating plasterboard?
I'm fairly sure that this method will work but any advice you could offer before I begin would be appreciated.
Thanks in advance
Thanks in advance
