Britony Combi 80
7 Jul 2006
Hi, a problem with the above boiler as it goes to lockout when DHW drawn, with CH some it goes alright for a short time and then it goes to lockout or it goes to lockout straight away, any help/
It might be a gas flame lockout but I think on that model its also the same indication for overheat.
Whats the temperature just before it locks out?
The secondary heat exchanger may be blocked and the CH return filter may be blocked.
A thermal survey would identify if these are the likely cause.
But then there are also gas related causes and they would need a registered gas engineer to investigate.
Tony Glazier
