Help required please. I have searched other posts but can`t find the answer.
I have a Gas Britony Combi 80 boiler. I have DHW working but no CH. I replaced both Throttle valves last year and have removed and cleaned all parts including filter on return, 3 way valve & heat exchanger etc. Pump is running fine, no air in system. It will fire and run for about eight seconds but cuts out. I think it is either the diverter or another throttle head failure but i am not sure if their is a way of testing whilst insitu. I have disonnected the DHW wiring from the throttle head and the water from the tap goes cold and the boiler does not ignite.
Can anyone advise how to test diverter (i have tried tapping it) or throttle heads.
Any help would be appreciated
Thanks in advance
Thanks in advance
