Morning.
Quick explanation of why I'm looking for this elusive little gadget:
DHW only fires when the hot water tap is turned to delivery quickly, but under those conditions the water passes too quickly through the exchanger to get much heat in it. Any slower and the boiler shuts off the DHW.
So, after much reading, I'm looking at the flow switch.
Thing is, where is it? The documents I got with the combi (in 2001) only show the device in a schematic diagram - it shows no pictures. A quick google (and eBay) shows a neat looking gadget which looks simple enough to find, you would think.
Interestingly, my doco says the following about replacing the flow switch:
The pics I found around the globe suggest that there's more to a flow switch than just the microswitch - possibly involving a piston?
Here are the pics I just took of the combi.
Where's the removable flow switch?
This is what I found on eBay, part number (600)81471
Can anybody help me find my flow switch?
Thanks.
21/12/2011: edited title to replace "80" with "SE"
14. DHW Flow Switch
Disconnect the electrical connections undo the securing clip and remove the microswitch; reassemble in reverse order.
Thanks.
