Brittony se80 faulty pump??
1 Sep 2006
Hi this is my first post so be gentle. Problem started with a sheared water press switch, water everywhere. Replaced this but now the 2A fuse keeps blowing on the PCb. Disconnected the pump and fan connections on pcb fuse did not blow, replaced them one at a time only blows on the pump, there is a slight leak on the pump. Question, is the pump kaput or maybe the electrics just got wet and is causing a short. Any ideas much appreciated.
Water in pump. Try drying it out or replace head with compatible standard CH pump - e.g. Danfoss, Wilo or whatever make it is.
Fink he meant Grundfos not Danfoss :P . Anyway make sure you match the pressure "head" of the new pump, if you only change the motor. Most combis use the 6 metre ones, not 5m.
