Hi all,
I've had a look in the manual and it doesn't seem to list this particular scenario so hopefully someone could shed some light on it...
It's getting on a bit (Glow Worm 24ci combi) and I've had to replace/clean out the heat exchanger a couple of times in the last 7 years, another part also had to be replaced which I can't remember what it was unfortunately. I haven't had it serviced in about 3 years.
A few days ago the pressure was lost I had to re-pressurise the system - all came back without any problem and had hot water/heating again. Yesterday the hot water stopped working mid-wash but the pressure is fine at 1.1bar.
The boiler is getting power to it (all lights are on, pressure reading correctly, no fault codes. The pilot light is not igniting though. I can hear what is presumably the fan whirring away but it's not sparking up and neither hot water nor heating kicks it into life. I've turned the power off at the wall for various periods of time, it seems normal when it turns back on and I can hear a couple of very quiet clicks (not as loud as a normal hob ignition so I can't say if it's definitely trying to ignite.
Any ideas?
Hopefully this is a quick fix and I can source the part myself! Cheers.
Any ideas?
