- Joined
- 24 Mar 2005
- Messages
- 20
- Reaction score
- 0
- Country
Hi. Have got an Indesit wg1130t washer. Has been making a rythmic tapping + scraping noise for past few weeks. This morning, wife turned washer on and it sounded like an high pitched drill with the drum not moving. Have taken the back off and found that the pulley has sheared off from its position with the stem into the centre of the rear of the drum. The remaining bit of the stem is 'retained' by a 17mm nut. How do i get this nut off, cos when I try to turn it, the drum rotates. Is it a case of holding onto the drum while trying to undo nut (tried, no luck). Have located spare pulley on internet so it must be able to be removed to allow for fixing of a replacement.
Thanks.
Thanks.
