Broken TV amp
11 Apr 2005
When I switch my TV to terrestrial channels i get no signal. I have a powered 'amp' or something in the loft where 3 internal tv cables come in and then the aerial cable from outside comes in. Then on my aerial pole outside I have the internal cable going into a box and the box has a cable going up to the aerial. I recently noticed this box had fallen down and had filled up with water so wandering if it now 'broke' its an Antiference UPF25U and i just want to replace it but cannot find one maybe too old. What can i replace it with please.
It's a masthead amp. You can just buy another masthead amp, but I would be concerned that moisture has got into the coax too, which would also need to be replaced.
I bought one to use in the loft about three years ago because you never know what might happen to an externally mounted job. Sorry, can't recall the make now but it was a four way job and British made for about £30; yes it has been perfect ever since.
