Brush Cutter Fuel Feed
OK.
Hope this helps
Forget the carb you require a spark. Just incase your not pulling it over fast enough while holding the plug to see a spark put a teaspoon of 2T fuel in the plug hole, yank it over and see if it fires..if you have carb cleaner you could give it a shot into the carb intake with filter removed. instead
I don’t recognise the machine but the carb is a Chinese Walbro.
The cut out wires are the red and black ones in the first photo. One will go to the switch, the other one back to the metal engine.
John
